ROTAX® 4-TEC® JET DRIVE ADVANTAGES
Sea-Doo® sport boats have distinct advantages over "traditional"¯runabouts.
Whistler, British Columbia, Canada - September 21, 2005 - Do what other boats don't. Go where other boats won't. Nothing on the water gives you a better sense of power, control and excitement than a jet drive. And when it comes to sport boats, no other brand brings you more innovative choices than Sea-Doo Sport Boats.
The safer way to boat
Because there's no propeller, you never have to worry about people boarding and reboarding a Sea-Doo sport boat in the water. No prop also lets you get on plane faster, giving you better visibility and allowing you to react to boating situations faster.
Direct Power
What happens when large volumes of water are forced through a 6 in (15 cm) nozzle with the aid of a few hundred horsepower? You get a tremendous amount of power directed toward a single point. It's the principle of jet propulsion. The engine turns a hidden impeller that pulls water through an inlet, into the pump and sends concentrated power out through the jet nozzle giving you a quick burst of acceleration when you hit the throttle.
Faster Planning
One thousand...one thousand two...you just accelerated to 20 mph (30 km/hr). You'll get on plane quickly with a jet drive. While most boats have to push water out of the way to get on plane, a jet drive pushes water in a straight line behind the boat instead of displacing water below the boat. So there's less bow rise, giving you a quick shot out of the hole. This gives you better visibility of what lies ahead and allows you to react to boating situations earlier. An added benefit of jet propulsion.
Quicker Directional Response
If you want a boat that responds to your every movement without lag time, then jet propulsion is the answer. Each Sea-Doo sport boat has fast reflexes. As the jet nozzle turns, it sends maximum thrust for instantaneous handling. And each Sea-Doo sport boat has a reduced 270o radius in the steering system for a tighter feel at the helm. On a Sea-Doo sport boat, you'll never want to get from point A to point B in a straight line.
Less Draft
You come to the water to get away from it all. Your boat shouldn't keep you from getting where you want to go. Which is why each Sea-Doo sport boat gives you greater access to shallow water. With a draft of only 12 in (30 cm) you have the ability to visit shallow coves, explore backwaters, or even head out on the water when lake levels are down.
BRP, a privately held company, is a world leader in the design, development, manufacturing, distribution and marketing of motorized recreational vehicles. Its portfolio of brands and products includes: Ski Doo® and Lynx™ snowmobiles, Sea Doo® watercraft and sport boats, Johnson® and Evinrude® outboard engines, direct injection technologies such as Evinrude E TEC™, Bombardier* all-terrain vehicles (ATV), Rotax® engines and karts. www.brp.com
®, ™, Trademark of Bombardier Recreational Products Inc. or its affiliates.
* Trademark of Bombardier, Inc. used under license.
For information: Tim McKercher - North American
Sea-Doo Media Relations and Competition Management
(321) 409-0519
tim.mckercher@brp.com
Ada Nazzari, Senior Advisor
International Marketing & Communications
(514) 732-7024
ada.nazzari@brp.com
Source: SeaDoo.com
Rotax 4-Tec Jet Drive Advantages
Started by Kevin Leclair, Sep 22 2005 12:27 PM
No replies to this topic
Posted 22 September 2005 - 12:27 PM
